Has anyone ever tried a setup where you have used an ublox M8N to connect to the LiDAR from Velodyne? I did all the wiring connections as you can see on my diagram. I got a PPS Locked on the LiDAR, but no GPS coordinates.
Someone has already make it work?
Yes, I used it, but I had no luck trying to create a map with it.
I think that a GPS RTK would be perfect, but the VLP16 is extremely limited with the GPS it accepts in its Interface Box. So I think the best solution is to connect a simple GPS to the Lidar just to have it working as a clock. And then syncing the data with an external RTK.
Rohan R Paleja said:
Oh okay,
have you tried to use the Veloview software? I think the GPS signal needs to be very accurate to create a precise map so a GPS with submeter accuracy could be used.
Pedro Henrique R. P. B. Silva said:
Hi, Rohan
I managed to connect the GPS, but I couldn't map anything with precision. I still have no idea how to map an indoor area. For outdoor mapping, I sync the GPS and IMU data from a pixhawk fc with the LiDAR points, but there's no precision in the map.
I am attempting to do the same thing. So was the veloview program able to map your room or surroundings accurately as the lidar was moved?
Hello, Matej
After many tries, I could make it work.
I had to do exactly as you said, reprogram the ublox using u-center and disabling every GNSS except GPS. I also had to access the pin 3 of ublox m8n to get the PPS.
But besides that, I had to connect an inverter chip (7404) between the TX of the GPS and the RX of the LiDAR. I will send the configuration file and the connection diagram. It might help someone in the future.
Thanks for your help!
Matej Miljko said:
Conectando GPS M8N ao LiDAR Velodyne(UPDATE).pdf
Config_para_LiDAR_update.txt
Hi Pedro,
I have no experience with this but after some google-fu I think this might be the answer:
First I saw this in Velodyne's manual:
Did you do that? If not I think you should be able to do it in Ublox u-center software.
You can connect the gps to program it using one of these methods.
This thread might explain your problem.
Or the gps had no lock.
Best of luck
