Distributor
LidarLite working correctly? - SOLVED
Hi
I am trying to set up a LidarLite sensor from PulsedLight.
I set it up according to the wiki (new sensor, manufactured Feb 2015, interfaced with a Pixhawk)
http://copter.ardupilot.com/wiki/common-optional-hardware/common-rangefinder-landingpage/common-rangefinder-lidarlite/
In the wiki it points to the Flight Data Screen to test the sensor,
but I only get zero as reading in this window.
But if I check in the terminal,
I can see that the sensor is working (see attached file),
so is it working ok? Is the wiki wrong?
Thanks a lot,
Felix
                  • Thanks for the quick replies.
                    I have watched that video during my installation as well.
                    We are coming here close to midnight soon. I will let you know what I find tomorrow.
                    Thanks a lot
                    Fred
      • Thanks Felix.
        Yes, I followed your video and I connected to the right ports.
        I will send it in by the weekend. Your help is much appreciated!
        Best Stephan
        • Stephan,
          I also have exactly the same problem as you had.
          My new LIDAR-Lite unit I have received yesterday has no data output.
          You have sent your unit to Felix Meissner.
          What did he find?
          How did you solve your problem?
          Thanks,
          Fred
  • Does someone has the Lidar working in AutoMission?
  • This reply was deleted.
      Are you powering the servo rail with either an ESC or BEC?  Double check you have the cables connected to the correct pins on the Pixhawk.  And I can see your running the 3.3beta which is great as it has the LIDAR support in it.  If it still doesn't work please post a dataflash (.bin) log file.
      Thanks, Grant.
  • Looking for help with altitude sensors
    In various flight modes including loiter I know that altitude is varied from the feedback from the sensor, however how do you use these rangefinders in a set mission? I appreciate that they have a working altitude and you are not aware of when they are active within a mission. Also that the inbuilt barometer takes over when the sensor leaves off. I also know there is an underlying database of height values that are drawn from Google which has a very limited accuracy.
    When planning a mission there are three options when setting altitude: relative I understand altitude decisions are made in reference to take off point determined by barometer; terrain I assume sets altitude from google database + the altitude set in the mission, as for absolute – I have no idea.
    I have Maxbotic MB1260 working on my Iris+ and can see it working in loiter over varied terrain however am reluctant to try and use it within a mission as I don’t understand if I would use absolute or terrain.
    David
    • MR60
      You understood it right. the altitude defined at each of your waypoints in a mission will be relative to the location where your armed the ship, if you are working in relative mode. In addition if you activated "terrain following", the google map known altitude will be added on top of that (the objective is that you avoid to crash into a hill).
      If you use absolute, your ship will just use the absolute baro altitude.
      • Thanks - do you know if absolute height uses other sensor data like that produced by sonar or a Lidarlite to supliment the baro data??
        • MR60
          No, either the altitude is derived from the baro or a sonar takes over under 7meters or a lidar takes over under 40 meters (as configured in the params).
          • Thanks Hugues - time for lidar i think
            David
