Linux-based Quad-Rotor Control
Hi Everyone,
just want to highlight our most recent developments on PenguPilot, a GNU/Linux based Multi-Rotor UAV Autopilot.
A Video with horizontal GPS position stabilization and vertical ultrasonic stabilization is avaliable here:
Gumstix Overo and Linux based PenguCopter from Tobias Simon on Vimeo.
The whole control process is implemented in C under Linux (PREEMPT Kernel). The latest source code is available here:
https://github.com/PenguPilot/PenguPilot
IPC among C and Python processes is implemented via ZeroMQ and MessagePack/Protobuf.
Regards, Tobias
  • robot challenge 2015
    gratulation zum gold im air race rennen!
  • Hi Tobias,
    could you tell approximate hardware setup for Gumstix Overo? It's hard to grasp completely from github repo which hardware you use with Overo. I mean sensors, etc.
    • Hi Aleksandr,
      - we use the 4 Timer/PWM outputs of the Gumstix for motor control using the OMAP3-PWM driver.
      - Drotek MPU6050/MS5611 Sensor board is connected to the Gumstix's I2C Bus 3.
      - Maxsomar I2CXL ultrasonic Sensor is connected to I2C bus 3 as well.
      - LEA-6 GPS receiver is connected to ttyO0 (NMEA output at 115200 baud, 10Hz update rate)
      - ACT DSL remote control receiver connected to ttyO2
      - Current Sensor connected to ADC channel 7
      - Voltage measured via ADC channel 2
      - Internal WiFi of the Gumstix für SSH
      3702500867?profile=original
      Cheers, Tobias
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
