  • Hi Vito,
    I am doing a similar project with a tricopter to be controlled by a Beagleboard. We also are using the Aeroquad sensor board at the moment.
    I am wondering if you have any advice for someone starting out with this.
  • I want to add some more information:
    - Protocol mavlink
    - Patched Qgroundcontrol to use the joystick in Guided mode (I also corrected the zero point of joystick)
    - Ability to webcam stream (I use 802.11bg wireless adapter but is possible to use abgn adapter)
    you can try the code on your linux box
