Is there a relatively currently list of frame/motor/esc kits in the 450-550mm range?
I'm looking to do my first build and would rather start with a known workable configuration. I'll be using Pixhawk to do mostly UAV exploring so flight time/stability > agility/speed.
Thanks,
-Drew
sorry things are not that straight forward in that range a lot of junk out there. keep things simple your looking at phantom size quad with phantom like motors and props swing 8x4 to 10x4 prop you can go low end 3S set up or expensive hiy end 6S setup or middle with 4S setup up to you really. Quattro ESC BL heli flash able is good ESC choice less hassle with setup. Air gear T-motor stuff is cool as well !
meany Quad frames out there up to you taste but you need a Tx Rx with s-bus support !
really cool frame carbon fiber here is a cool 4S safe setup with 2 axis gimbal recommend 8x4 props
http://brushlessgimbal.ca/Multi-Rotor-Products-Parts/Frame/ZF450-KI...
ESC
http://brushlessgimbal.ca/index.php?main_page=product_info&cPat...
MOTOR
Outside of the DJI/3DR kits there aren't as many ARF kits in this size as I would have expected. Thanks for confirming.
