logs erased themselves (2.8.1)
I went out for a test hover today and it was just to collect so data. All I wanted was 5 minutes of RAW logs to look at.
Came home, loaded up the mission planner, and connected.
And it erased the logs all by itself :( I never got see them yet, Was I just unlucky or what?
Mike
3690996925?profile=original
  • T3
    It looks like it auto downloaded and then erased your logs. Did you check the log folder to see if there might be some log files? Do you have telemetry? If yes, you can check the tlogs.
  • Allow me one question:
    Why do you use such an old version? You should update to the newest version and then try again...maybe the error is fixed already.
    Not sure, but that's an old version of the code. There have been no reports of that with the current versions (2.9.x). I suggest you upgrade.
