Longer arms on 2014 3dr quad frame
Anyone have longer arms they have used for the 2014 diy 3dr frame.  These dji 12" props will be to big and that is what I will be required to use with the motors I have(e600).
Hoping someone designed some newer arms that also have more screws hole to mount the motor on instead of the stock arms (only 2).
Thinking carbon fiber could be cool too if it fits snug.
Thank you for any help in advance!
  • You can make your own custom length arms by using 6061 or 6063 3/4" square aluminum tubing, 1/32" thickness I believe. I was thinking the same re: going to a 12" prop and SunnySky motors with lower KV.
