Looking for a flying wing
Hi all.
I'm trying to find plans for a very basic flying wing design. Simply put I'm looking to build a non swept wing UAV out of balsa. The kind which would look like a rectangle from above. Can anyone help?
Thanks all :)
  • T3
    Have a look at the Aviona plans at the bottom of this page, http://www.rcgroups.com/forums/member.php?u=132180.
    ios's blog - RC Groups
  • That is a bad design for a flying wing as it wont be stable.
    Suggest you use a slope RC foamie..they are good as indestructive
    The BEE or Queen BEE might be suitable
  • Hi and thanks to the links i was sent.
    I'm currently building a foam flying wing using the plans from RCGroups..
    http://www.rcgroups.com/forums/showthread.php?t=281606
    I was wondering if anyone could advise on what size (Kv & diameter) motor and esc I should install.. I've already got some 1300Mah 7.4V Lipos which I'd like to use too if possible.
    Any advice appreciated.
    Thanks.
  • Here is one that's completely scratchbuilt, and just about what you're describing. Its the KFm "plank" called the Nifty.
    http://www.rcgroups.com/forums/showthread.php?t=1077013
  • There are picktures of one at: http://www.rcgroups.com/forums/showthread.php?t=1186781 If I remember correct Dean Goedde had a some posts about the build a while ago, but I couldn't to find it.
