Magnetometer problem
Has anyone here have any issues with the APM 2.023and the magnetometer?I installed the Version APM2.023and all I'm getting from the magnetometer is zeros. I'm not getting any data from it. In the setup I enabled it and it was working with version APM 2.020 but after I installed 2.023 I only get zeros. I did reset the APM but still I'm getting the same problem. May I please get some advice as to why this is happening? Thanks.
    Did you re-enable it after you installed 2.023? Pls go through the full setup process again in the Mission Planner, which is always a good idea when you load new firmware.
