MAV Proxy Module cannot be loaded up?
I have a question on MAVProxy. When I start MAVProxy, I got the following errors:
Failed to load module: No module named wp
Failed to load module: No module named rally
Failed to load module: No module named fence
After playing around with it, I found that there are more modules that I can't load. E.g. tracker and cameraview. I might know why cameraview is not loading up (see P.S. below), but after looking at the mavproxy code, I'm still not sure why all the other modules fail to load. Any suggestion?
P.S. Camera view -- I'm having trouble installing cuav-1.3.2 which might have led to cameraview not working. When trying to run "python setup.py install", the process terminates because python.h for chameleon.c is missing. Any info on this?
Thanks,
  • Hi Edwin,
    I am facing exactly the same problem as yours. If you managed to solve it, please tell me how.
    Thanks.
    • It's Ok now, I t seems that I didn't install the OpenCv.
      Thanks anyway
