MAVlink OSD Battery A & B Configuration
Please look at the images I have uploaded.
I seem to be missing something on these.
On my Goggle screen, both A & B voltages come up as 0.0 but the Current appears as a value.
What are the adjust PINS being referenced?  Have they anything to do with the Pixhawk?
I have tried lots of combinations with no luck.
There seems to be no manual for any of this.
  • Jim, given I'm reading this on a mobile phone, I don't see your images, but I think you might be referring to voltage pins on the OSD board itself, the way you have it configured. I.e. To use these you would need to somehow connect your flight battery to pins on the OSD board itself (probably through a voltage divider to reduce the voltage level) so they can read the voltage directly. I wouldn't recommend this though.
    Instead you should be able to choose Mavlink Voltage as the voltage source - this will then come from the pixhawk telemetry (for Bat A at least) in order to display the voltage read by your apm power brick. The same applies to the current configuration - select Mavlink.
