Mikrokopter
Hi, anyone out here familiar with the pressure sensor of the Mikrokopter?I need to calibrate it to hold an altitude of 1m max.Regards,|MAVERICK|
  • Hi,
    Yeah actually it works fine. With the newer firmware or rather the new MK tool, I was able to activate and calibrate it effectively.My problem now lies with flying it with a 29MHz Transmission or 2.4GHz as the current one flies on 72MHz.
    Any suggestions?
    Cheers!
    |MAVERICK|
  • Mine does that fine out of the box. I think you can also adjust the Gain the new MKtool settings. Just use the height control and set it at 1m. You can also try using the Varrio Adjust. I know I meter is kind of low but mine seems to do it fine
    http://mikrokopter.us
    Mikrokopter.us
