Helyo Sergio de Faria Pereira - The XSR has a CPPM output, see the instruction manual (which comes with the product and is available on the FrSky website) for more info on that. The APM 3.1 has a CPPM input, see Andrew Gill’s comment above for a diagram.
Helyo Sergio de Faria Pereira's Discussions
Helyo Sergio de Faria Pereira's Discussions | The largest amateur Unmanned Aerial Vehicle (UAV) community. Quadcopters, robot planes and more!
I've connected mine OK. All I had to do was adjust the cals to get the readings accurate. Can you measure the voltage and current signals on the back of the APM pm connector?
Has anybody had problems getting the voltage/current monitor to work on the APM Mini 3.1? I have everything connected properly but both MP and OSD register 0 for voltage and current. No changes to any settings seem to work. I thought I had read on another forum that this is a problem with the 3.1 but that people have gotten it to work. Can anyone confirm this and if so what did you do to get it working.
Could someone help me connect the FrSky XSR receiver to the Mini APM 3.1?
or you can get a set of this...no need to do GPS soldering ... one cable connected to both compass and gps
http://www.aliexpress.com/snapshot/6612275664.html?orderId=66839701...
Just started experimenting on these boards...
Has anyone any idea as to if it's possible to connect a differential pressure sensor (aka speed sensor) on these boards?
Also can status leds and a buzzer work with this? if so, where should i connect them?
Ps: The internal magnetometer does seems reliable... should we bother connecting an external one?
Thanks !!
nice toy Euan
