Hmm just looked those pictures more closer.. their text says:
Features: - Use APM firmware and ground station, no need to modify
- No onboard compass, which makes this version ideal for use with multicopters and rovers
But looking more of those pictures I can clearly see HMC5883 compass on board and no clear ways to disable it. Also it seems to have wrong memory components as all Chinese clones have. None of Chinese companies really know what are correct components for APM boards and same continues here.
Board seems to miss all decoupling capacitors for main CPU. I can see a lot of browning outs and weird reboots with this board. Along that it's powersystem seems to miss several protections or at least I did not see those on these pictures.
After some of you guys get those, please post pictures to confirm.
Ok, why they then say that "No onboard compass" :)
As our real APM2.6 board we really do NOT have that compass. Even cutting down traces have shown some issues on some boards. Best way to disable it 100% is by removing whole compass chip.
I'm surprised that there is an internal compass jumper on these boards (I hadn't noticed that before) as the spec states 'No onboard compass'. Strange.
Out of interest, did the (external) compass work before you cut the jumper?
Other than that, it's a neat looking small pcb :)
Jani / jDrones
Original ArduCopter manufacturer / developer
Oh well..
Question? Do you have to do this if you have the 3DR GPS?
Thanks in advance...
The green Chinese characters in the first pic means:
The solder pad pointed by the arrow here has the same functionality as the JP2 jumper on an APM. It is used for firmware upgrade.
And white in the second pic:
Telemetry port, pins from left to right are GND, 5V, TX, RX
Thanks Dieter.
Hi Dieter,
Have you been able to test the board?
As there is precious little independent information about these boards publicly available any review of the board would be greatly appreciated.
Cheers,
Shane.
lol.... cloners :
http://witespyquad.gostorego.com/flight-controllers/minireadytoflye...
at least this guy's boards all work.
someone has already test ti?
1
2
3
4
5
of 5 Next
