MinimOSD Arduino code
hey guys,
Well, i am working on a project using apm2.8 ardupilot, and i need to make a live transmission video using MinimOSD. I have found the code on DIYDRONES repository on github, but it seems that its not up to date with the version of Arduino IDE, so i need to know with wich version this code will compile.
I have tried version( 1.67/1.6.6/1.6.5/1.6.4/1.6.3/1.6.0/1.0.5) without any success
In my case, i need to edit the code of MinimOSD
While compiling the code in Arduino IDE, i get error.. it depends on the version of the arduino platform ..
For example, for the arduino version 1.6.7(latest version), i get an error in "FastSerial" library:
"error must include fastserial.h before the arduino serial driver is defined with minimosd"
I have tried several version of Arduino, they all had a compile error.
-The code is provided on Github:
https://github.com/machaalany/MinimOSD-Extra/tree/master/MinimOsd-Extra_Copter
-And the libraries are:
https://github.com/machaalany/MinimOSD-Extra/tree/master/librariesOK
--> can you please let me know with wich version of Arduino this code should compile ? I am in very need for this code to compile because i need to make some modifications
elie
  • I am using Arduino 1.0 + Visual Studio + VisualMicro plugin. I have heavily modified MinimOSD though, removed tons of stuff I don't need, added flight time estimation, added internal settings screen instead of additional panes.
    I used minimOSD-extra + librariesOK as a base.
    • thank you for your reply konstantin !
      Well you said Visual Studio + VisualMicro plugin .. can i know how ? and to modify what does the screen display, i should modify the arduino code? or the Visual Studio/VisualMicro plugin code ?
      Please explain as much as you can
      regards
      • You can look at my repo: https://github.com/kosmikkosmik/apm-osd - it contains Visual Studio solution. Basically there is both Arduino and C++ code, I just used to work with C++ that's why the code I've added is in C++ rather than Arduino stuff.
        Just install:
        * Visual Studio Community Edition (it's free for personal use)
        * Arduino 1.0
        * Visual Micro
        Very much modified MinimOSD for Copter. Contribute to kosmikkosmik/apm-osd development by creating an account on GitHub.
        • okey mate thank you for your help :)
  • Hi
    I just compiled with 1.0.5 . Is not a problem with the version. I had some problem with the libraries
    I did my personal relase , changed  the altitude information and used to understand the mavlink messages
    I  used  AC3.2.1 so  i did chekout from the  official repository:
    "git clone -b ArduCopter-3.2.1 https://github.com/diydrones/ardupilot.git --single-branch ArduCopter-3.2.1"
    Open the folder with librariesOK and copy it in your Arduino program path
    ..\Documents\GitHub\MinimOSD-Extra\librariesOK
    In the Arduino go in preference and  write the path  (In my case i use git in windows )
    ...\Documents\GitHub\MinimOSD-Extra\MinimOsd-Extra_Copter
    This is the result , hope will be useful
    3702192984?profile=original
    http://diydrones.com/profiles/blogs/ac3-2-1-default-streamrate-chan...
    minimOSD-howto.pdf
    • Dear Domenico,
      Thank You very much for your how to file, this is actually what i want get in last one week. I want to get invole in mininosd coding so i get fully customized on this.But very hard to get starting point for me.
      Just now, i do fast read on your how to file, still didn't get 100% understanding on it, but I will read it again and again. I hope I can get future help from you to get smoothly on minimosd coding.
      Thank You again,
    • thank you for your help mate, finally it compile :D .. do you know if this code will work with ether Apm 2.8 and Pixhawk ? version wont be a problem ?
      • it works with anything that outputs Mavlink 1.0 , that's any recent ArduPilot project.
        • Btw, loading the code into OSD will be enough for its to work properly and to display data on screen right  ?
          nothing else is needed ?
        • okey mate thanks alot :)
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
2 hours ago
12 hours ago
DIY Robocars via Twitter
12 hours ago
Friday
Friday
Thursday
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Thursday
Thursday
David Hori liked Isabella Domi's profile
Jan 12
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
RT @RoboticMasters: Thanks to @EllerbachMaxime and the Sydney Uni Capstone Students the @donkey_car @diyrobocars simulator is getting a ma…
Jan 11
Jan 6
Dec 28, 2020
An interesting line-following simulator to use with with your robocars: https://github.com/ron-grant/LFS
Dec 23, 2020
Dec 23, 2020
