So do I need a telemetry to use the minim OSD? Or can I just have my APM 2.5 and the minimOSD and be fine? I just want to know if I can fly it with all the data and sensors with just these two things.
Al,
Yes you can use MinimOSD without telemetry. The more sensor input you have with the APM the more effective your OSD will be. Minimally a GPS unit would be recommended, and would be required anyway for autonomous flight. If you haven't already found it, check out the MinimOSD-Extra project here and the related discussion here. It's a parallel project to the Arducam project and has a lot of great activity. This would be a great place for you to learn about the capabilities of your MinimOSD.
Good Luck!
Nathaniel ~KD2DEY
