Dear Mission Planner development team,
i have just downloaded both the zipped as well as the 64 bit MSI version of the APM 1.1.79 and now it does not start anymore. I get the following in the console, i assume it got to do with directx.
I am currently trying to update directx on my machine and just posted this in case somebody else has the same issue.
Cheers
Florian
---LOG---
INFO Program - ******************* Logging Configured *******************
INFO Program - Max Threads: 1000
FATAL Program - Fatal app exception
System.TypeInitializationException: The type initializer for 'ArdupilotMega.Main
V2' threw an exception. ---> System.IO.FileNotFoundException: Could not load fil
e or assembly 'Microsoft.DirectX.DirectInput, Version=1.0.2902.0, Culture=neutra
l, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system canno
t find the file specified.
File name: 'Microsoft.DirectX.DirectInput, Version=1.0.2902.0, Culture=neutral,
   at ArdupilotMega.MainV2..cctor()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\M
icrosoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure lo
gging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fus
ion!EnableLog].
   --- End of inner exception stack trace ---
   at ArdupilotMega.MainV2..ctor()
   at ArdupilotMega.Program.Main() in C:\Users\hog\Documents\Visual Studio 2010\
Projects\ArdupilotMega\ArdupilotMega\Program.cs:line 56
gging.
ion!EnableLog].
  • Installing the file directx_Jun2010_redist.exe downloaded from http://www.microsoft.com/en-us/download/details.aspx?id=8109 fixed the problem.
    It seems APM uses directx10 as of Version 1.1.79.
    Cheers
    Florian
    DirectX Redist (June 2010)
    This download provides the DirectX end-user redistributable that developers can include with their product.
