Gday for some reason when I try to retrieve 'Old Firmware Versions' I get an error (see attached screen cap). I had gotten a previous version a little while ago then all of a sudden I cant. The reason I want an older version is that anything above XXXXXX gives a 'Bad Gyro Health' error due to this particular board being a lesser quality copy and the ascociated voltage reg checks done with later versions.
Not sure if anyone can help out with this issue but it would be great if you could. I've tried it on 3 different PC/Laptops at home but no joy....
3691110326?profile=original
    this is a github issue, try again in an hour or so.
    • Ok cheers.
      I'll just ask is this something you'll be able to resolve and in 'about an hour' would be likely when it would be resolved or do you mean in general?
      I only as because I have been getting this error for atleast a week so I was starting to feel like it was my network for some odd reason.
        it is a network issue. and could be just your setup. as it works fine here in Australia
        • No worries. I'm in Brissy. Prob just my setup.
          • Hi There
            Totally new to all this but I was also trying to load an older firmware version because I have a cheaper board (and trying to avoid the 3.1 issues with bad gyro msgs etc).
            However I've downloaded Mission Planner (latest version) onto two PCs and I can't get it to allow me the option of selecting the old firmware versions.
            I go into the Initial Setup then Firmware and hit Ctrl and O but nothing pops up.
            Any advice would be greatly appreciated.
            Dave
