I just installed APM 3.2rc1, from 3.1.3, on my hexa. Flew a short flight, came in to download logs and I can't do anything in terminal. I've tried hitting "enter" 3 times, made sure I'm connecting within 20 seconds. I grabbed my bare 2.5 board, also 3.1.3, installed 3.2rc1 and now that one will no longer work in terminal either. I tried MP 1.3.1 build 1.1.5229.30673 as del as beta MP 1.3.1.2 build 1.1.5234.14291.
Also tried a second pc with MP 1.3.1 with no luck. I'm not really sure if I should post here or in the APM section. Any suggestions are appreciated.
Thanks,
Barry
edit: I did an erase/reset on each board prior to installing 3.2rc1, so terminal was functioning normally immediately prior to the firmware installation.
    3.2 is removing the cli.
    • Well that would explain it! Thanks Michael.
  • Just reinstalled 3.1.4. Terminal works normally again. This was on my bare board, and I wasn't able to do an erase/reset because of the fact that I couldn't get terminal to work with 3.2rc1. Mod, should this be moved to the APM forum?
