mission planner hangs when getting params
When attempting to connect it hangs on getting params. It seems to show gettijng different params each time. I can connect with a "cntrl T" (without loading params)
Sometimes it will say it received only 1 heartbeat.
This thing was working earlier but things happen.....
Any ideas.
    What radios are you using ?
    Can you connect using USB without issue?
  • more info.
    It did just connect and it worked. so I attempted to do a radio calibration. No lines showed up. Everythng was basically gray. No movement. I have the receiver connected with and the inputs are set correctly to the APM. Like I said this worked earlier.
    I am at a loss
Aug 25
