I'm running Megaplanner on kubuntu 13.04.
Everything seems to go fine on startup. However I'm not able to use my telemetry because the arrow on the drop down box for choosing the baud rate is not available.
There is a white rectangle over the place where the selection widget should be. Is there maybe some startup option where i can set the baud rates from the commandline?
Also, try using arrow keys.
