I cannot get the compass test to work in Mission Planner.
The mag is working in HUD and is enabled etc.
What am I missing? Is this a MP issue, a setup issue, a mode issue, serial, baudrade, a stupid user issue?
Mission Planner 1.2.35 mav 1.0 and ArduPlane V2.70 (ArduPlane V2.69 has same issue) and AP 2..5+ board.
Here is how I reproduce problem:
Connect power via usb, open Mission Planner, after boot finished, connect, etc click on Terminal.
Display on pc shows init Arduplane V2.70 and command list as it should
type test OK get test back
type compass
Mission Planner gives no response and hangs. Click Terminal or reboot etc to clear the hang
If I do the same thing as above but...
type setup OK get setup reply
type compass then I get the results of the current compass data => OK
Using the Ardunio IDE (for Version 2.69 Arduplane) and terminal mode for CLI then:
type test
type compass gives the current compass data.... so Arduplane code and AP2.5+ board must be good. but see next..
At one time the "test / compass" actually worked in the Mission planner with V2.70.???? Don't remember the sequence of events. Then it quit working again. Also, at one time I could not get CLI Test / compass it to work in Arduino IDE, CLI
Doing a little debug in IDE when CLI test compass was hanging the call toe compass::init() never returns. (print statements before and after the call)
I have some more data.
I am using the Windows version of everything - Windows 7 to be precise. (This may be one clue)
Using Mission Planner: (workaround)
Click [Terminal] (note board starts the reboots but Mission Plannerl puts it into CLI mode (most CLI commands work) but test / compass does not. some others do not.
In the main CLI menu Type "reboot". This starts a reboot.
As board starts to reboot, hit Enter three times. AP should go to CLI mode.
Now test / compass and other CLI commands seem to work OK.
Using Arduino IDE:
Go to Tools, Serial Monitor. Note that the board starts to reboot.
Hit Enter 3 times. This puts the code into CLI mode.
Now here is the trick. Note at the bottom right of the Serial Monitor window are the options for the Enter key.
* That option has to be "Carriage return" for the CLI interface to work correctly (Using Windows PC)
If that option is set to "Both NL and CR the test compass completes but the Heading, xyz and offset data list does not start it's listings (Probably because NL starts test, CR stops listing???)
If that option is set to "NewLine" the the command for test compass does not work
Conclusion: (Supposition on my part)
Mission Planner: Clicking terminal seems to send the three Enter messages to the board during bootup but somehow does not set the "Carriage return" option. Doing the reboot, then hitting Enter three times seems to set it up correctly. Seems to be a Mission Control software issue. Apple vs Unix vs Windows Enter key differences?
IDE: Operator Error. Operator must set up Serial Monitor correctly for the ArduPlane code to work correctly.
Hi, Dennis, I have the same problem, but on APM 2.0. Some help to solve this?
