Mission Planner UDP and TCP/IP Connection
I have been trying to get the Mission Planner to accept UDP and TCP/IP inputs.
I keep getting a time out error on a UDP  connection.  I have tried various playback rates and real-time rates, but I always get a time out error.
Is there anything special with UDP and TCP/IP connections?
Thanks,
Warren
    both tcp and udp should work. it is required to be 2 way however.
    • This reply was deleted.
        MP replies to the same ip/port that the packet originates from.
            please use something like wireshark to see what is going on.
              • Hello. I'm on a similar project. Which tcp port did you use to connect to it? Have you tried UDP port 14550? Thanks in advance.
    • Do you have some example code?
      How do you do a two way on UDP?
    • No.
      I am thinking about just adding another receiver.
      That should be an easy way to bypass the problem.
