I have tried to update Mission Planner 1.2.97 build 1.1.5167.24804 and get the following error message:
"Update Failed File downloaded does not match hash: it-IT/MissionPlanner.resources.dll"
What does this mean and what should I do to correct it?
I've been trying to update the firmware on my mediatek GPS with Mission Planner 1.2.98 build 1.1.5187.14200. This involves uploading custom firmware to the APM prior to the update, however, there is no option on the initial setup/install firmware screen to select a custom firmware image. Is this an oversight or will I have to roll back to an earlier version to get this functionality?
you need to enable advanced mode.
Thanks very much, Michael. (I don't do this very often).
give it a day and try again. this is usauly because of a corrupt download/proxy server
I tried to update today from 1.2.96 and get the message "update failed file downloaded does not match hash". Will try again tomorrow.
I really hope someone will fix it.
Tried again today with the same result-no update and same message.
please try this
http://firmware.diydrones.com/Tools/MissionPlanner/MissionPlanner-l...
Thanks Michael, that worked. I moved my logs etc. to new folder created and all is well !
Sorry for my ignorance,
but what files/folders have to be moved to maintain a system that works as before?
Logs + ???
