Hi Guys
After an external compass upgrade I was trying to configure last night and Mission planner was connecting to the board no problem.
This morning though Mission planner wont connect, I also cant get the unit to arm either.
Attached is the error message.
Any help much appreciated.
  • Hi friend,
                Only reason for this you will have to check your comport as well as baud rate .Sometime its happens normally...
    UNMANNEDENGINEERIA
    www.unmannedengineeria.com
    Unmanned Engineeria | Expert unmanned engineeria makers
  • T3
    Double check you com port and baud rate. Your screenshot shows 2400 baud rate.
