Modelling buildings
Hi all
Was wondering if anyone knows how to autonomously capture images for photogrammetry of buildings. The idea would be to set up a spiral flight plan around for example a tower with a common point of interest.
regards
  • Stephen thanks
    This info has helped alot. I am busy processing dense cloud now after 2h of marker matching :)
    Stephen Zidek said:
    Dave,
    In photoscan you must have the photos window up, and double click a photo to bring it up on the main viewer.  From there you can zoom in to add markers.  I usually use roof corners because they are visible from the ground and air.  Each individual marker needs to be tagged from multiple different photos in both chunks.
  • Thanks Mario
    Very cool model
    MarioSpeedwagon said:
    As stated before, Tower can do this.
    This was done with Tower, 3dr solo and a stock GP4.
    https://skfb.ly/LErs
  • Thanks Will
    Im onto it :)
    Will Fellmeth said:
    Dave,
    Yea the ordering of these messages is getting pretty messy rather quickly.
    The MAP2 from skysight/seegul does work with the A5000 as well as the samsung NX1100. Its all on their website (http://skysight.eu/). We have had great success with produces from skysight/seegul. When you go to place the order for the MAP2, it asks you for the manufacturer and model of the camera your using and automatically sets you up with the other cables and such that you'll need.
    Cheers,
    Will F
  • T3
    Dave,
  • Dave,
    Cheers,
    Will F
    "skysight.eu"
  • Hi Will
    The ordering of these messages gets confusing.
    Thanks once again for your feedback. I have a correction to make though. Our camera is a Sony A5000 not A7.
    Our other camera is a Samsung NX1100 which triggers perfectly from a APM 2.6 but continuously triggers from a Pixhawk.
    I need to get a cable or two which can trigger these cameras.
    Do you know whether the previous advice you gave me on the trigger cable would still be relevant?
    Best regards
    Will Fellmeth said:
    Dave,
    So, for the camera trigger cable we use a SkySight Mono (shown in the picture i attached), it goes from the AUX output of the Pixhawk to the micro USB of the Sony. Apparently Skysight has gone out of business because when I go to their website I'm directed to here (http://skysight.eu/) which is a company called 'Seggul' (why their website is skysight, I'm sure I do not know). They have a similar product they call the MAP2, you just need to get the servo cables and USB cable to use it, and they have helpful tutorials on their website that shows you everything you need to know. And here's a wiki page on the Mono (http://ardupilot.org/copter/docs/common-camera-shutter-triggering-f...).
    Now for your model. We don't use photoscan for our 3D models, we use Pix4D mostly (sometimes agisoft). We only use photoscan for stitching together 2D panoramic images for things like power line inspection. So point of the story, I'm not too familiar with photoscan's process to make 3D models. But I can tell you that when their are blurred spots in our 3D models, that means there was poor overlap between images or the stitching algorithm couldn't find good tie points. So to fix this I recommend increasing your overlap between images. Our standard is 80% forward and 60% side.
    Hope this helps.
    Cheers,
    Will F
    Dave said:
    Hi Will
    Many thanks for your constructive feedback. We also have a Sony A7 and a machine which uses a Pixhawk FC. Unfortunately we do not have a trigger cable which works for this. Do you have any recommendations on where we could find this?
    Currently we are using another setup with a Samsung NX1100 which works really nicely and I will be testing using this setup.
    I have done a few models of houses and buildings so far but in all cases I have found certain areas to be blurred or twisted. Stephen mentions manual alignment in Photoscan?
    I guess that Photoscan gets confused if you enter top down pictures with aerial view from around the building and ground data all in one data set?
    Looking forward to your response
    Dave
    Will Fellmeth said:
    Dave,
    There are a whole bunch of ways you could go about doing this. I personally like one of two options: using a pixhawk controlled Turbo Ace Matrix with a Sony A7 camera or using a DJI Inspire with their X5 camera. The former requires a more tech savvy and open to do some research individual but provides better images with smaller Ground Sample Distances (GSD), while the later is more lay-man friendly but does not have the image quality of the former. As for modeling software I prefer Pix4D or Agisoft. And as for the actual flights to capture the images, I would do one nadir flight over the building to capture its top and surrounding area, and then follow up with a number of oblique flights (depending on how tall this structure is and what GSD your looking for) around the structure.
    This is a (very) quick explanation of the processes my colleagues and I follow to do our photogrammetry. If you have more specific questions please don't hesitate to ask.
    But to directly answer your question, yes many people (including myself) have experience doing this kind of work.
    Cheers,
    Will F
  • Hi Stephan
    Thanks again for the advice. I am currently working on this. I dont know how you find common points from a sparse point cloud though. It seems impossible to me.
    Hope to figure it out soon
    Regards
    Stephen Zidek said:
    Dave,
    I start photoscan with two chunks.  One for the aerial photos, and one for the ground photos.  Sparse cloud on both.  From there I manually add markers to features which are visible both from the air and the ground.  I then align chunks by marker, then merge chunks.  Then I do further processing like dense cloud.
    I made this using this method.
  • Dave,
    Hope this helps.
    Cheers,
    Will F
    Dave said:
    Hi Will
    Dave
    Will Fellmeth said:
    Dave,
    Cheers,
    Will F
    "skysight.eu"
  • T3
    Dave,
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
22 hours ago
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
