Has anyone got a modified 9XR working with MAVLINK on ArduCopter 3.2.1 with HobbyKing OrangeRx TX & RX flashed with Gitsly branch of OpenLRSng?
I set the 9XR & TX all to 115200 as well as set the SERIAL1_BAUD to that of SERIAL0_BAUD @ 115200
(I have tried all the lower rates as well, 9600, etc.),
copied default SR0_ parameters over to SR1_ parameters so they are now identical to each-other
(a suggestion from another member on another thread)
and my received packets displaying on the 9XR are coming down at approximately 1 packet per second with no voltage or amperage readout.
If anyone can tell me precisely what I need to do in order to get this to work properly, it would be greatly appreciated!
Please, no guessing, I have been guessing at this for 30+ hours now to no avail. I need someone that has done this before and has a working setup with the above mentioned gear.
Knowing my luck, it's something as simple as the version of the "Gitsly" firmware is outdated and I need to be using openLRSng for Chrome and tweak a single setting for it to work.......I need that person that knows!!!!!!!
