I need to monitor the my GCS simulation from another laptop through tcp or udp. Is it possible? Can i also have control over it to modify the settings. So that i can change settings in MAVProxy .
Is it possible to use Mission planner instead of APMplanner2? And Can I connect mavproxy from one laptop and Mission Planner in Another laptop using UDP/TCP ?
yes ,just use the --out parameter on mavproxy , APMplanner2 can also output a UDP stream
