  • As the conversation started from the perspective of "a beginner," I had avoided mention of Hall sensors and other special features. For most applications a low cost power module works just fine. The voltage and current sensing for these low cost power modules can be calibrated to achieve an accuracy sufficient for most applications. The mRo power module is a step up in quality and performance at a price comparable to many lower quality power modules. For larger, higher voltage planes we often use Mauch power modules (https://www.mauch-electronic.com/) They also have Hall sensors with an architecture that works well at high voltage and current.
    Pedro Matabuena said:
    Take a look the Power Modules that has mRobotics manufacturers in the USA, excellent quality. Especially check out the one with the hall sensor, which makes it extremely accurate across the entire current range. (mRo Hall Sens Power module ACSP7)
    https://store.mrobotics.io/category-s/114.htm
    3702468985?profile=original
    100A / 200A Hall Sensor PM for Pixhawk / APM
  • Take a look the Power Modules that has mRobotics manufacturers in the USA, excellent quality. Especially check out the one with the hall sensor, which makes it extremely accurate across the entire current range. (mRo Hall Sens Power module ACSP7)
    Home
  • Thanks! I´ll check them out
  • As a beginner, select a power module that is rated for your max voltage and current with power and signal cables matching your battery, aircraft, and flight controller. Should your needs become more demanding, you might want a power module with more accurate current sensing. We have soem good quality power modules with XT60 and JST-GH connectors at www.KashmirWorldFoundation.org.
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
15 hours ago
15 hours ago
Derrick Davies liked lisa TDrones's profile
16 hours ago
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
