Motor LEDs Behaviours
Hi, I had a look at the codeof update_motor_leds(void), and I think it might be usefull to code some logic in order to have visual signification from these motor LEDs.
I will try this, which test Motor arming ang GPS lock. I have a quad in X configuration:
static void update_motor_leds(void)
    static bool blink = false;
    static int blinkCycle = 4;
    // Motor not armed : Test GPS
    if(motor_armed == false){
      switch (g_gps->status()){
          case(2): // GPS lock : Blink front/back
          if (blink){
              digitalWrite(LE_LED, HIGH);
              digitalWrite(FR_LED, HIGH);
              digitalWrite(RI_LED, LOW);
              digitalWrite(RE_LED, LOW);
          }else{
              digitalWrite(LE_LED, LOW);
              digitalWrite(FR_LED, LOW);
              digitalWrite(RI_LED, HIGH);
              digitalWrite(RE_LED, HIGH);
              break;
          default:  // GPS not lock : Blink sequence
              digitalWrite(LE_LED, ( (blinkCycle == 4 ) ? HIGH : LOW));
              digitalWrite(FR_LED, ( (blinkCycle == 3 ) ? HIGH : LOW));
              digitalWrite(RI_LED, ( (blinkCycle == 2 ) ? HIGH : LOW));
              digitalWrite(RE_LED, ( (blinkCycle == 1 ) ? HIGH : LOW));
              break;
  }else{ // Motor armed : Blink Simultaneously
          if(blinkCycle <2){
          } else{
    blink = !blink;
    //blincking cycle management
    blinkCycle--;
    if( blinkCycle<1) blinkCycle = 4;
    // the variable low_batt is here to let people know the voltage is low or the pack capacity is finished
    // I don't know what folks want here.
    // low_batt
  • 100KM
    Would be a nice addition !!!
