Motor Test Mavlink Message
It appears that there is support for testing individual motors according to this wiki:
https://code.google.com/p/arducopter/wiki/AC2_Props_2
and it looks like there are commands here for motor tests:
https://code.google.com/p/arducopter/wiki/AC2CLI
(The code was moved here:
 http://github.com/diydrones/ardupilot
but I don't see the ac2cli program.)
Is there a MAVLINK message for testing individual motors?  I browsed through the common.xml messages, but didn't see an obvious one.
I'm using ArduCopter 3.1rc2.
Thanks,
Rob
    The "test", "motors" command is still supported in the CLI.  It's discussed a small amount at the bottom of this new wiki page.
    Maybe what threw you off is that it use to be "setup", "motors" but it seemed like more of a "test" than a "setup" to me so I moved it in the CLI.
  • There is no command in Mavlink to test the motors as such. The commands you linked are part of the APM software and can be accessed through command-line interface. They spin the motors one-by-one in a cycle.
    If you just want to spin a particular motor, it would be easiest to connect the ESC's directly to your RX, bypassing the APM.
  • I found the CLI in the Mission Planner Terminal. Is that using a different protocol than MAVLINK to control the motors?
