I'm currently using a 3 cell 5000mah LiPo batter. The battery connects to the 3DR Power Module, which connects to a wire harness power distribution. This PD connects to each of the ESCs which connect to the motors.
This problem wasn't happening before and only started last week:
When I'm calibrating the motors, or just checking the throttle after arming, eventually all the motors except 1 stop spinning. I use the voltage checker on the battery and it says it still has 10.6/11.1 V left.
I don't understand what could be causing it. We charge the battery for only a few seconds and it seems to fix the issue, but eventually it happens again. Any ideas?
It does this during manually 1 per 1 calibration. All motors would calibrate successfully, but when checking if they spin by moving the throttle, 3 motors spin normally for a few seconds then slowly die and stop. The 4th motor works as intended.
This is fixed for a time by charging the battery for a few seconds like I mentioned in the Opening Post.
How do I balance my LiPo?
