Motors're Not Responding
Hello everyone.
I just finished building my another ArduCopter using DJI F450 frame today. However, i came across an issue. My motors don't spin after i armed them. I already pre-troubleshot by checking all the connections between APM to Radio, ESCs to APM, and ESCs to Motors. All look fine to me.
After Arming the motors, the Red LED on APM2 becomes solid and only Blue LED keeps flashing. Does this say anything? I have added video links to this post so you can see whats going on.
I used the same ESCs and the same motors on my another quad and they worked great. I have had any issue with them.
Quad Specs:
HackerStyle 20-22L Motors, APM2, 2.7.1 ArduCopter Code, Turnigy 25Amps ESCs (BEC: Liner Mode 5V/2A),  Turnigy nano-tech 4000mah 25-50C battery, DJI F450 Frame
https://www.youtube.com/watch?v=8zGoP4duwdQ
https://www.youtube.com/watch?v=hVZdPg7kREg
Thank you so much for your time and your help.
Cheers,
Kur
  • after watching the video you are moving your stick in the wrong direction.
    down + Left is disarm and down  + Right is Arm.
  • did you run thru the ecs calibration?
    if you did not do this the the esc them self didn't arm.
