MP view of Overlap when using /AutoWP/Survey/Grid V2?
1. I like using the Grid V2  method a lot. But is there a way to view the Overlap and Sidelap, and adjust them, when using this method of flight planning?
2. In 'Grid' , and 'Simple' tab, there is a checkbox for 'Camera top facing forward'.  Is this the same as in Grid V2 - Landscape?   If they are the same, could they be labeled the same?
3. In Grid V2 there are sections on the right labeled 'Aircraft'  and 'Mission'.  In Aircraft, if you select an aircraft from the drop down it will set the min/max speed values, and a max mission time.
In the lower section there is another speed setting: Speed[m/s] .
Question is which one is really used to control speed once you upload a mission to your aircraft?
Thank you
  • >>Grid V2 was a beta experiment
    Thank you for that info, I did not know that. Hmm, V2 is pretty quick and easy but if it is not really going anywhere I will focus on V1.
  • I believe Grid V2 was a beta experiment that has been sort of abondoned. All development has continued on V1. I use V2 sometimes as a tool to make rough estimates.
