Posted by Venkatesh Sai on January 1, 2010 at 4:42am
I loved the way the Easy Glider Pro flew but it had a Problem from the FPV Point of View it had a front Mounted Prop which was causing disturbances in the camera hence had 2 options1) Convert to twin Motor2) convert to pusher .Decided to go for the later after it had a horrific crash from around 60 ft directly into the ground nose first at full throttle . The Best part of MPX is you can build the plane back even after such crashes .SPECS: Wingspan: 71" (180.3cm)Length: 43.7" (112.3cm)Flying Weight: 28.5oz (810g) with standard power systemTook two aluminum angles and drove them into the fuse just behind the wing at an angle such that the thrust line of the motor would be 1/2" to 1" above the CG point of the glider ( this is very critical ).Since I have sufficient nose weight by way of FPV/UAV equipment the extra weight behind the CG should be OK.Here are some photo's .She glides beautifully with a RCFORALL 2217/1500 KV Motor .Here is a Video :[url]https://www.youtube.com/watch?v=_KJ9OmfDVI0[/url]Sai
Hi Sai, thats good work , keep it up. I have seen this mod with your post else were. Where did you get your easy glider from? Happy new year. BTW are you RCFORALL ?
Morli
BTW where are you from
Morli
