Mtk 3329/adapter not responding
Thank you for reading my discussion. I received all of the components
listed below within the last two weeks.
As the manual states, I have read and reread the manual and trying to
take things step by step. I have included the ArduPilotMega.Pde file.
The following describes my issue. Once again,
thank you in advance for any help!
- Radio and flight control mode setup successful
- Everything outside and running at least 15 minutes.
- MTK 3329 gps and adapter (with battery on backside) connected
to APM
- 3.249 volts at VCC pin 1 on gps module
- switch #2 (adjacent servo reverse switches) in the 0 position (closest
to servo output pins)
- Blue led on adapter (gps) flashes in 2 second intervals.
- never get solid blue on adapter
- open serial connection via IDE. run GPS test.
Here is the problem. While running the GPS test via IDE serial
connection the result is a continuous stream of -------------.
I understand that the flashing blue light on the adapter indicates
the module is searching for gps signals. However, I would expect to see
something other than a stream of --------- during the GPS test even without a GPS Lock.
If it is even possible, can someone explain how to update Mtk firmware
using the mini usb connection?
I am familiar with Power Flash
Components:
MediaTek MT3329 GPS 10Hz
MediaTek MT3229 adapter
ArduPilotMega IMU Shield/OilPan Rev-H
ArduPilot Mega - Arduino Mega compatible UAV Controller
sku: GPS-09710
Any thoughts?
Thank you in advance,
Joe
ArduPilotMega.pde
    If you're not getting GPS lock (solid blue LED on the module) outside after 15 minutes, you may have a faulty module.
    You can modify the sketchfile here to interact with the module directly without a FTDI cable.
