Hi, friend of mine has a problem with his multicopter with Pixhawk flight controller. When he tries to fly it vertically at high speed - multicopter starts climbing rapidly...
He tried to diagnose the problem but he have found no solution so far.
Here is the log:
https://dl.dropboxusercontent.com/u/98312667/log%20z%20quadro.BIN
One possible problem I see - vibrations in the Z axis, but I'm not sure if it might cause such behaviour...
Also, have a read of the Common Problems section of the following page:
http://copter.ardupilot.com/wiki/flying-arducopter/flight-modes/alt...
Looked at the logs. Your Z axis vibrations are pretty bad! Looks like you're flying in Alt Hold which requires the vibrations to be minimal. Z vibes need to be between -5 and -15. Yours are between 0 and -40 in some places.
Lots of Z can cause fast climbs.
http://copter.ardupilot.com/wiki/ac_measuringvibration/
Haven't had a chance to look at the log, but could this be transational lift? I have a 450 quad that climbs rapidly when travelling horizontally at high speed. I have to compensate by lowering the throttle.
