Hi all,
I received my Iris+ couple day ago and I meet a lot of problem with it.
First, after charge over 4hours battery, I turn everything on. But yellow flash light is always blinking and I couldn't arm what ever I try.
Second: My controller couldn't show battery infomation.
Everyone have any idea what happen and how I could fix it?
Hi all, after long holiday in my country. I come back to solve old problem and I met new problem. My younger brother try to make drone work but It doesn't work not ly but also damage my controller. I have no idea why my controler couldn't show any thing like pict above when I turn it on. Anyone could tell me?
It might help if you were to tell us what your brother did. It is difficult to say what is wrong when we can't see anything and we have no idea what was done.
when I ask him, He said he have no idea what he did (just click something >.<)
Hard to tell you what to undo when we don't know what was done. Good luck.
Hello badboy2, everything on the pictures looks normal.
please start MissionPlanner on a PC, connect, now on the "flight data screen" it will be shown up why your iris will not arm.
Another option ist to upload your logfile here in the forum that we can have a look on it.
very best Hartmut
Isn't the battery showing 12+ volts on the display? I don't understand why you think it is zero.
So....did you look in the manual about what is required to arm the IRIS?
I mean controller show no database ... mah battery capility.
You typically can't arm with only 5 satellites in view. (your photo shows 5 sats on the display)
I've no idea what a yellow light is.....I don't have an ISIS. Perhaps it flashes when you don't have satellite lock?
Did you get a manual with your gear? Does it explain these things?
Thank Stu. But even When I get 10 sat, Iris+ couldn't arm. And I have no idea why battery status show "0" on the controller.
