This is the Hexa setup I need, but I'm not sure what I need to configure in the motor.pde file
//Hexa Diamond Mode - 6 Motor system in diamond shape
// L CCW 0.Front.0 CW R // 0 = Motor // ......***...... // *** = APM // L CW 0.....***......0 CCW R // *** // ......***...... // *** // B CCW 0..Back..0 CW B L = Left motors, R = Right motors, B = Back motors.
I noticed in the motor config that the orientation for the hexa is that there is a front and rear motor like the + config in the quad. But my frame is more like X setup, with the front of the hexa and APM pointing in the middle of the front two motors. ie. I have a front right, front left motor, I have a right and a left motor, and I have a rear right and rear left motor. So I need to change the motors.pde
Can someone please explain to me this code in motors.pde so I can make amendments to suit my frame. My motor setup should be
FrontLeft
FrontRight
Left
Right
RearLeft
RearRight
#if AIRFRAME == HEXA // Hexacopter mix LeftCWMotor = constrain(throttle + control_roll - (0.5 * control_pitch) - control_yaw, minThrottle, 2000); // Left Motor CW
LeftCCWMotor = constrain(throttle + control_roll + (0.5 * control_pitch) + control_yaw, minThrottle, 2000); // Left Motor CCW
RightCWMotor = constrain(throttle - control_roll - (0.5 * control_pitch) - control_yaw, minThrottle, 2000); // Right Motor CW
RightCCWMotor = constrain(throttle - control_roll + (0.5 * control_pitch) + control_yaw, minThrottle, 2000); // Right Motor CCW
FrontCWMotor = constrain(throttle + control_pitch - control_yaw, minThrottle, 2000); // Front Motor CW
BackCCWMotor = constrain(throttle - control_pitch + control_yaw, minThrottle, 2000); // Back Motor CCW
#endif
FrontLeft
FrontRight
Left
Right
RearLeft
RearRight
#endif
