Hi folks...
New to this.
Have an APM 2.5+ and a Turnigy 9x radio.
I have been able to successfully fly, but only with full pitch trim down (as selected on the radio by pushing that little trim switch forward).
I have calibrated the sticks using the radio's own internal menu/calibration system, and I have repeatedly did the radio calibration inside mission planner (see attached pic)...but yet, my pitch trim is way off. Any ideas?
Thanks...
Other thoughts...
Did you check the leveling calibration? In short, with the aircraft level in two axis, right side up, does the Mission Planner Flight Data screen horizon show level?
It is unlikely but...is the APM mounted level to the airframe? A 1/16 inch difference from one end to the other is too much.
This still seems like a radio calibration issue but if the other questions above are in play, it will all add up.
-=Doug
Does the radio have a subtrim setting? If so, it could be way off.
I am not familiar with the 9x, flying Spektrum here.
-=Doug
However, check the pic... You can see that the pitch "range" is off center... Its biased toward the top of the pitch bar, which is pitch back, or nose up of course.
So it apprears to be an electronic calibration issue. But I can't figure it out.
