My Pixhawk Setup
I was able to get 5 flights in today mostly in loiter and it's pretty rock solid. I am curious what it will do with a little wind.
Here are my params for a Trex 550 stretched to a 700 running 1500 RPMs. 3691129941?profile=original
3691129897?profile=original
Trex 3.1.5 001.param
    • KDE motors are a must have for these helicopters they very reliable.
      Yes I 3D printed the GPS mount. I also printed the plate that the Pixhawk sits on and the battery tray. I can send you the files if you want them?
      • looks great!!!
        Id like the 3d files please.
      • I also have a trex 550 and plan to mount pixhawk too.
        so could u send me the files ? Please , i really want it too much.
        Thx u advance :D
  • Really thanks a lot for your sharing
    • Sean,  I'm curious about what your motor spec's are.  Are your frame plates the stock 49mm apart?
      David R. Boulanger
      • David,
        Yes my frames are the stock width. My motor is a little outdated but still works very well. I was running 2 7s 7800 MAH batteries and getting 30-35 minute flight times.
        Motor Specs
        http://kdedirect.com/KDE600XF530.html
        • Thanks for the reply.  great flight time.  I did not know of any low Kv motors that were that small in diameter.  Thinking of stretching my 550 to a 600. If I do my stock Align 1220Kv has got to go.
          Regards
          David R. Boulanger
  • Great!
    You must be a well experienced RC pilot.  Good job with the mountings.
