I opened my quadcopter frame for added power switch on my gimbal to be able to turn off when I do not use it. once finished I close the frame, I plug the lipo to test whether my switch worked well but
My pixhawk suddenly stop working! it is a sequance beep at startup. LED remains dark and missionplaner do not connect it to the pixhawk. it yet well recognized by windows in device manager.
I also tried a reset of the pixhawk unsuccessfully
Here is the video of the problem:
can you help me?
After some research I found several conversation he had flashed the Bootloader PX4IO "px4io-v2_default.bin" on pixhawk with the software "Qgoundcontrol"
qand but I try flashing the "px4io-v2_default.bin" I have a bootloader error message (see below)
Attempting to upload file:
C :/ Users/TooT/Downloads/px4io-v2_default.bin
Found PX4 board on port COM8
[PX4 Uploader] scanning for bootloader ..
[PX4 Uploader] synced to bootloader
[PX4 Uploader] using firmware from C :/ Users/TooT/Downloads/px4io-v2_default.bin
[PX4 Uploader] found bootloader revision: 4
[PX4 Uploader] found unsupported board ID 9, exiting
Wrong board ID, aborting.
Upload aborted and failed.
I checked the SD card. inside it there was a "APM" folder and inside that folder there is a "boot.log" file. when I open it with the text editor there cried "No PIO board found"
