MyTwinDream The material quality of: EPO
MyTwinDream Data:
Wingspan 1800mm
Body length 1220mm
The internal maximum width is more than 13CM
The internal maximum length is 86CM
MyTwinDream: is a multi-platform carrier-based aircraft, and there are video recorder installation platforms (points)(supporting the installation of 2-axis and 3-axis platforms) on the top of both the head and the fuselage
The machine body has giant capacity which can support the mirrorless camera's down installation(the maximum width of inner space is more than 12CM)
Fast disassembly available for the whole plane: horizontal tail/vertical tail/main wing
Main wing (which could be assembled according to your own preference) 1) Divide into left and right segments (traditional) 2) Divide into four segments with small volume, which is convenient for going out 3) Stick two wings in the middle segment to the fuselage (prepare for the flight rapidly)
MyTwinDream recommends:
2814 High efficiency motors x 2
HobbyWing 30A ESC x 2
9g servo * 4
9x6 propeller x 2
Cables and XT60 connector
MyTwinDream FPV Plane:www.mymfd.com
Hey
The link you have put "MyTwinDream FPV Plan......." is pointing to some dating site.
I wanted to know more about this aircraft.
