Posted by UAS_Pilot on September 24, 2012 at 7:35am
Is there a simple way to control Navigational lights on and off using the APM 2.0? I would like to use a software switch to enable and disable the lights in flight.
any help or insight would be great.
You could use an unused servo channel for this. In them Mission planner there is a special waypoint type (DO_SET_SERVO) which can change a servo channel output on APM (that way, it would also be possible to change the lights directly from the Transmitter).
I am using an ATtiny85(~$3) to switch some additional stuff. I am only switching LEDs, you probably would need a FET to switch more powerful lights.
Example ATtiny85 code:
/** * Read PPM signal * * Decode r/c receiver PPM servo signal and turn lights on * according to servo position. * * $Id$ */
// from which pin to read. #define PIN_PPM 0 #define PIN_POS1 3 #define PIN_POS2 4
// the length of the pulse (in microseconds) or 0 if no pulse // started before the timeout (unsigned long) unsignedlong duration, lastgood = 0; intposition= 0;
I found this great website to help you compare products and brands: http://www.nauticexpo.com/boat-manufacturer/navigation-light-398.html
I just use this controller on my quad, with the really high vis LED's:
http://www.braincube-aero.com/index.php?main_page=product_info&....
Runs off a single channel. Simples. Warning: it's heavier than you might think.
#define PIN_PPM 0
#define PIN_POS1 3
#define PIN_POS2 4
unsigned long duration, lastgood = 0;
int position= 0;
void setup() {
pinMode(PIN_PPM, INPUT);
pinMode(PIN_POS1, OUTPUT);
pinMode(PIN_POS2, OUTPUT);
digitalWrite(PIN_POS1, LOW);
digitalWrite(PIN_POS2, LOW);
//Serial.begin(115200);
void loop() {
duration = pulseIn(PIN_PPM, HIGH, 20000);
if (duration == 0) {
duration = lastgood;
} else {
lastgood = duration;
position = map(lastgood, 1000, 2000, 0, 2);
if (position > 0) {
digitalWrite(PIN_POS1, HIGH);
} else {
if (position > 1) {
digitalWrite(PIN_POS2, HIGH);
} else {
Best
-S
