Naze32 Rev6 need help identifying part
Hello people,
A month or so ago I built by first quad. I spent a while learning how to fly. Just when I was getting used to the transision from angle to rate mode, I crashed hard. After that, channels 1, 2, 3 and 4 were no longer received by the naze32.
After a couple of hours of troubleshooting, I found out an IC broke off the naze32, breaking the connection from channel 4 to the MCU. I already have a new naze on the way, but I was wondering if someone could help me identify the missing part. If I could resolder it and fix the naze it will be a nice backup board for when I break the new one. =) Here's a picture with the missing IC spot circled.
Thanks a lot in advance!
Greetings,
Mike
3691338092?profile=original
  • I believe the part is a voltage regulator. Here is a link to a picture that shows the number. Here is a Digikey link to the part. The part is only $1.58. Go for it and see if you can repair it.
