  • I've used the Nyrius Aries Prime tx/rx and also I've had a wireless router that was connected to my ground station computer like the D-Link WIFI AC750 portable router and battery charger to power my FPV goggles as well as transmitting to DTV's.
  • Wouldn't the DJI Phantom 3 HDMI Output Module work for you? This would allow you to view the live 720p video stream from the Phantom in real-time.
    • WOW! Right under my nose! I think this is exactly what I need. And $99 is really sweet. Thank you, Nick.
      • I got the unit, and installed it. Now nothing works. It won't connect with the copter. Anybody have a solution?
  • If u have a smart TV u might be able to get the camera signal on it but how reliable it is idk I'm going to try it with mine I'll let u know how it works for me and try and give u a range
    • Best of luck post ur solution when u find it I would like to know how everything works out for u
    • Thanks, Kris. I don't have a smart TV. Your info will be much appreciated.
  • I tried to find something like that and had no luck but what u can do is get a fpv transmitter for ur go pro and an av reciver for ur dji and u can run live stream and it would be more accurate as far as taking any delay out of the feed u get from the WiFi
