Hi everyone.
I am very stuck on how to get a RSC mode setup on my TREX 800. When I am in the heli setup menu and I want to click and pull down on the tab for the RSC there is nothing there to pulldown, it is just blank. I have a YGE ESC that has a nice governor and I want to use the ESC's governor. I have been trying to figure this out for a while now. Please any help would be grateful.
David
rule #1 is to use 'Full parameter list / tree' and check every input after 'Refresh'. MP often manipulates your inputs on the 'user friendly screens' which can be surprising !
Ofcourse there is the outdated wiki and H_RSC_MODE and I think you want H_RSC_MODE = 1.Usually you find good description in parameters for copters (heli support is not very good).
Remove your blades for testing (sometimes you have to carry the heli around to make it think it flies) and don't forget fail safe, i.e. what happens if you shut down the TX, what if you remove the cable between RX and Pixhawk, etc. !
