Need help with Ardu 3DR Esc setup!
So I just got the 3dr quad copter but im having issues getting the escs to calabrate?
Ive tried Auto calabration and manual more than twice each, and I cant get the motors respond after calabration? Durring the ESC calabration the motors will spin up, directly after moving the throttle down, but after I unplug the battery, and replug the motors will not spin up.... and moving the throttle/rudder in the indicated manner from the manual will not ""unlock" the motors?
Im not sure why its not working, The only thing I could think is I dont have the magnetometer hooked up at the same time? (Some Ardu-copter failsafe not to fly without Magnetometer?)
Any advice?
  • T3
    I assume you calibrated your radio first? ESCs can be hard to sometimes calibrate. You might try reversing your throttle.
  • Also im using FlySky TH9X tx/rx?
