Need help with Mission Planner not connecting.
I have been building a quadcopter for about 2 mos.
I apologize if this is posted in the wrong spot; if so please advise.
I am using a CriusV2, 3dR and Minimum OSD.
I get the MP firmware downloaded just fine and I even get the settings downloaded and saved just fine, but when I try to connect to MP I get an error.
I have solid green lights on both the Ground and  Air modules of the 3dr and the smaller red and green lights flash when loading data.   I am using the correct port and I have it set for the 57.6k baud rate.
I have screen shots to show the settings which I hope someone will recognize what the problem may be.
I appreciate all help.   Thank you all for what you are doing this is a fantastic site!
  • I am new to this, and I am wondering since there are no replies to my post.. that I have may have violated an unwritten rule that this forum is for guys using the APM controller and if you are using something else, like a Crius, you should be posting somewhere else.....and if that is the case, I am sorry.   I only asked because I am trying to figure out if I have a problem with the mission planner, but honestly, it could be with the OSD, or ???
    Just looking for some help.
