Hi Everyone,
Have a 2.9.1 quadcopter which flies really well in stabilize mode but when I attempt to use Loiter or RTL, it takes off at maximum climb. It's easily recoverable by switching back in to stabilize mode again but don't know whats wrong. Also, when it takes off, the first few metres seems to read the altitude correctly (sonar maybe?) but as soon as it gains some height the altitude soon goes negative. The altitude seems to be correct, but negative values. I am new to RC in general but I am thinking the neg altitude issue may be related to the loiter/RTL problem?
I do have sonar fitted which I have tested in the CLI and it is working but I have tried with the sonar on and with it off and makes no difference to the behavior in loiter/RTL mode.
Thanks,
Les
Hi Guys,
Tried putting the APM on to a foam pad, also loosen'd the wires going to it. Checked that the foam block is inside the APM (yes it is). Result is I took it out today and it performed absolutely the way it should. Alt hold, loiter and RTL performed really well except vert landing speed in RTL is a bit slow...
Thanks HEAPS for your help everyone!!
Les
I crashed in some snow today and the APM got wet. I dried it out and when I plugged into Mission Planner I noticed the altimeter was showing something like negative 2 million. I did the CLI test altitude and it was outputting normal numbers, +/- a few centimeters. So I erased EEPROM, reloaded 2.9.1, and re-input my config settings and viola! Fixed. Maybe a drop of water got on my baro and I needed to reset things after that egregiously bad data? Not sure
Ted
